[GRASS-dev] v.what.strds: timestamp column
Veronica Andreo
veroandreo at gmail.com
Mon Jun 15 13:49:59 PDT 2020
Hi Martin,
Afaik, v.what.strds is just a wrapper for v.what.rast for all the maps in
the raster time series. It does not consider the column time in the vector.
Then there's t.vect.what.strds that uses a space-time vector data set
(STVDS) to query a STRDS, but in my opinion to create a STVDS is a bit of a
hassle (one vector map per date).
The only module that I'm aware of that takes a vector with dates to query a
STRDS is Luca's add-on t.rast.what.aggr (
https://grass.osgeo.org/grass78/manuals/addons/t.rast.what.aggr.html), but
it's aim is to get aggregates before or after the dates provided in the
vector.
HTH,
Vero
El lun., 15 jun. 2020 17:20, Martin Landa <landa.martin at gmail.com> escribió:
> Hi,
> I am playing with `v.what.strds` in order to get space-time-related
> nearest raster value information from strds based on given timestamp
> stored in attribute table.
> Input: vector map with timestamp column, eg:
> cat|time
> 6|2020-01-08 03:00:00
> Goal: get a single raster value from strds based on timestamp.
> cat|time|value
> 6|2020-01-08 03:00:00|253
> Instead of that v.what.strds returns a new column for each raster map
> registered in strds.
> cat|time|map_1,map_2,map_3
> 6|2020-01-08 03:00:00||253|
> Is there any other tool which could do the job or should I modify
> v.what.strds in order to solve this task? Eg.
> v.what.strds time_column=time ...
> Thanks for in advance, Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200615/c23e74ee/attachment.html>
