[GRASS-dev] [GRASS GIS] #3577: Add rename and delete of Location and Mapset in Datacatalog
GRASS GIS trac at osgeo.org
Mon Jun 15 20:59:26 PDT 2020
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:              |     Status:  closed
  enhancement            |
  Priority:  normal      |  Milestone:  8.0.0
 Component:  wxGUI       |    Version:  unspecified
Resolution:  duplicate   |   Keywords:  datacatalog, location, mapset,
       CPU:              |  rename, delete, move, remove, g.mapset
  Unspecified            |   Platform:  Unspecified
Changes (by wenzeslaus):
 * status:  new => closed
 * resolution:   => duplicate
Comment:
 The initial issue migrated to !GitHub as Issue 710 with more details
 included. Closing.
 https://github.com/OSGeo/grass/issues/710
 Nikos Alexandris, jidanni, please open new separate issues on !GitHub if
 you are concerned with the CLI or documentation.
 //BTW, I used resolution "duplicate" which seems okay, but should we add
 "migrated" as a new resolution to Trac just to make clear for everybody
 which one to pick when closing a ticket here after opening a new issue on
 !GitHub? Or is duplicate clear enough?//
Ticket URL: <https://trac.osgeo.org/grass/ticket/3577#comment:5>
