[GRASS-dev] OSGeo4W winGRASS 7.8.2 needs rebuild due to PROJ upgrade? or a python issue?
Helmut Kudrnovsky hellik at web.de
Sun Mar 1 02:02:06 PST 2020
just opened OSGeo4W winGRASS 7.8.2 in the OSGeo4W environment. it just
worked up to a few days ago.
build information:
C:\>g.version -breg
version=7.8.2
date=2019
revision=3900fb114
build_date=2019-12-11
build_platform=x86_64-w64-mingw32
build_off_t_size=8
 ./configure  --host=x86_64-w64-mingw32 '--with-libs=C:\OS3944~1/lib'
--with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
--prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
--includedir=/c/OSGeo4W64/include --without-x --with-cxx --enable-shared
--enable-largefile --with-fftw --with-freetype
--with-freetype-includes=/mingw64/include/freetype2
--with-proj-share=/c/OSGeo4W64/share/proj
--with-proj-includes=/c/OSGeo4W64/include
--with-proj-libs=/usr/src/grass782/mswindows/osgeo4w/lib --with-postgres
--with-postgres-includes=/c/OSGeo4W64/include
--with-postgres-libs=/usr/src/grass782/mswindows/osgeo4w/lib
--with-gdal=/usr/src/grass782/mswindows/osgeo4w/gdal-config
--with-geos=/usr/src/grass782/mswindows/osgeo4w/geos-config --with-sqlite
--with-sqlite-includes=/c/OSGeo4W64/include
--with-sqlite-libs=/usr/src/grass782/mswindows/osgeo4w/lib --with-regex
--with-nls --with-zstd --with-odbc --with-cairo --with-opengl=windows
--with-bzlib --with-liblas=/usr/src/grass782/mswindows/osgeo4w/liblas-config
libgis_revision=00000
libgis_date="?"
proj=6.2.1 <=
gdal=3.0.2
geos=3.8.0
sqlite=3.29.0
PROJ was upgraded in the OSGeo4W framework a few days ago:
C:\>proj --version
Rel. 6.3.1, February 10th, 2020
not sure it's the reason for following error in the console:
C:\>Traceback (most recent call last):
  File "C:\OSGEO4~1\apps\Python37\lib\ctypes\__init__.py", line 97, in
CFUNCTYPE
    return _c_functype_cache[(restype, argtypes, flags)]
KeyError: (<class 'ctypes.c_long'>, (<class
'grass.lib.ctypes_preamble.String'>,), 1)
During handling of the above exception, another exception occurred:
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\wxgui.py", line 105, in
OnInit
    from lmgr.frame import GMFrame
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py", line 51,
in <module>
    from lmgr.layertree import LayerTree, LMIcons
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\layertree.py", line
38, in <module>
    from mapdisp.frame import MapFrame
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapdisp\frame.py", line
33, in <module>
    from mapdisp.toolbars import MapToolbar, NvizIcons
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapdisp\toolbars.py",
line 22, in <module>
    from nviz.main import haveNviz
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\main.py", line 24,
in <module>
    from nviz import mapwindow
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\mapwindow.py", line
42, in <module>
    from nviz.workspace import NvizSettings
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\workspace.py", line
23, in <module>
    from nviz import wxnviz
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\nviz\wxnviz.py", line
51, in <module>
    from grass.lib.gis import *
  File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\gis.py", line
475, in <module>
    ('checker', CFUNCTYPE(UNCHECKED(c_int), String)),
  File "C:\OSGEO4~1\apps\Python37\lib\ctypes\__init__.py", line 99, in
CFUNCTYPE
    class CFunctionType(_CFuncPtr):
TypeError: item 1 in _argtypes_ passes a union by value, which is
unsupported.
OnInit returned false, exiting...
or it could be a python 3 update yesterday:
http://download.osgeo.org/osgeo4w/x86_64/release/python3/python3-core/?C=M&O=A
python3-core-3.7.6-1.tar.bz2	10M	2020-Feb-29 23:07
C:\>python
Python 3.7.6 (tags/v3.7.6:43364a7ae0, Dec 19 2019, 00:42:30) [MSC v.1916 64
bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
