[GRASS-dev] [GRASS GIS] #3883: GRASS master does not compile with Python 3 on Mac
trac at osgeo.org
Wed Mar 4 16:02:08 PST 2020
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.8.3
Component: Default | Version: svn-trunk
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by cmbarton):
I can confirm that I finally got GRASS to compile and run with this fix.
Great news. I did have a problem with the installation that I had to fix
manually and hope I can find a way to deal with it in the build process.
Maybe a result of the difficulty in setting up a build environment that
does not use Python 3.7.6 (current stable) so I can create a Mac app
package. I will work on it more on the coming weeks to see if I can turn
out some useable new packages. Hopefully it will now be easier to finally
get to some of the other annoying to serious bugs. Thanks to all who
worked on this
Ticket URL: <https://trac.osgeo.org/grass/ticket/3883#comment:31>
