[GRASS-dev] silly question
Vaclav Petras
wenzeslaus at gmail.com
Wed Mar 4 18:37:29 PST 2020
Thanks Anna for identifying this. Looks likely.
Markus, Michael, I don't see the bad URL anywhere on Trac wiki, grasswiki,
or in CONTRIBUTING.md file (as far as search works for URLs, it does at
least for Trac).
Michael, The CONTRIBUTING.md file has SSH URL for your fork and HTTPS for
the OSGeo upstream repo, so your problem was not caused by that.
Nevertheless, switching to HTTPS also for the fork is something we can do
if more people support it.
Vaclav
On Wed, Mar 4, 2020 at 9:11 PM Markus Neteler <neteler at osgeo.org> wrote:
> Michael,
> Michael Barton <Michael.Barton at asu.edu> schrieb am Mi., 4. März 2020,
> 19:11:
>> Thanks Luca,
>> I also found someone here that pointed that out. I originally got
>> instructions from the GRASS WIKI.
> Which URL?
> Markus
> There is either an error or it is something that does not work for Macs.
>> The examples use a colon to indicate the repository owner instead of a
>> slash. I had fixed that for the original clone command but did not catch it
>> for the one setting upstream.
>> Also learned a new one that is exactly what I need in some circumstances:
>> git reset --hard origin/master
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Head, Graduate Faculty in Complex Adaptive Systems Science
>> Arizona State University
>> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, https://complexity.asu.edu/csdc
>> On Mar 4, 2020, at 3:30 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> Hi Michael,
>> On Wed, 4 Mar 2020 at 19:49, Michael Barton <Michael.Barton at asu.edu>
>> wrote:
>> I want to do something that should be simple but it is not. I want to be
>> able to update my fork of GRASS source code from master. The wiki
>> instructions say I should be able to do this with:
>> git fetch upstream
>> git rebase upstream/master
>> But when I do, I get:
>> unable to access 'https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=
>> ': Port number ended with 'O
>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=%20':%20Port%20number%20ended%20with%20'O>
>> it seems wrong the url, it should be
>> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_OSGeo_grass.git&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=2s0FIt9ZZMaEF8dGFczUzV71CeMzJZ3MBNeNaOmhcp4&e=
>> Any suggestions? I don't want to have to keep forking and cloning
>> Michael
>> ciao
>> Luca
>> www.lucadelu.org
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200304/9b71d9df/attachment.html>
