[GRASS-dev] silly question
Anna Petrášová kratochanna at gmail.com
Thu Mar 5 04:51:33 PST 2020
On Wed, Mar 4, 2020 at 11:29 PM Michael Barton <Michael.Barton at asu.edu>
wrote:
> See
> https://trac.osgeo.org/grass/wiki/HowToGit
> For example:
> git clone git at github.com:your_GH_account/grass-addons.git
> cd grass-addons/
> git remote add upstream git at github.com:OSGeo/grass-addons.git
> does not work for me at least. It needs to be:
> git clone git at github.com/your_GH_account/grass-addons.git
> cd grass-addons/
> git remote add upstream git at github.com/OSGeo/grass-addons.git
> Are you sure about this? This definitely doesn't work for me, if you use
https it needs to be:
git clone https://github.com/*YOUR-USERNAME*/*YOUR-REPOSITORY*
> replacing git at github.com:your_GH_account with git at github.com
> /your_GH_account
> Maybe the colon works if you have an ssh key set in your github account.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, https://complexity.asu.edu/csdc
> On Mar 4, 2020, at 7:37 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Thanks Anna for identifying this. Looks likely.
> Markus, Michael, I don't see the bad URL anywhere on Trac wiki, grasswiki,
> or in CONTRIBUTING.md file (as far as search works for URLs, it does at
> least for Trac).
> Michael, The CONTRIBUTING.md file has SSH URL for your fork and HTTPS for
> the OSGeo upstream repo, so your problem was not caused by that.
> Nevertheless, switching to HTTPS also for the fork is something we can do
> if more people support it.
> Vaclav
> On Wed, Mar 4, 2020 at 9:11 PM Markus Neteler <neteler at osgeo.org> wrote:
>> Michael,
>> Michael Barton <Michael.Barton at asu.edu> schrieb am Mi., 4. März 2020,
>> 19:11:
>>> Thanks Luca,
>>> I also found someone here that pointed that out. I originally got
>>> instructions from the GRASS WIKI.
>> Which URL?
>> Markus
>> There is either an error or it is something that does not work for Macs.
>>> The examples use a colon to indicate the repository owner instead of a
>>> slash. I had fixed that for the original clone command but did not catch it
>>> for the one setting upstream.
>>> Also learned a new one that is exactly what I need in some
>>> circumstances:
>>> git reset --hard origin/master
>>> Michael
>>> C. Michael Barton
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=pAhL9Y2iEzu8CenXO-1i6_H9r36a9CPGOFayiqlOt-c&s=dTgptB10Y3OLPNysWxkA0pqjDP-S80sUXJAZ8fqNX3k&e=>
>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__complexity.asu.edu_csdc&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=pAhL9Y2iEzu8CenXO-1i6_H9r36a9CPGOFayiqlOt-c&s=4TNsPkQF0F95MCFJgIoaX8eO2T6GqP6mUwHcKgn_Lm8&e=>
>>> On Mar 4, 2020, at 3:30 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>>> Hi Michael,
>>> On Wed, 4 Mar 2020 at 19:49, Michael Barton <Michael.Barton at asu.edu>
>>> wrote:
>>> I want to do something that should be simple but it is not. I want to be
>>> able to update my fork of GRASS source code from master. The wiki
>>> instructions say I should be able to do this with:
>>> git fetch upstream
>>> git rebase upstream/master
>>> But when I do, I get:
>>> unable to access 'https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=
>>> ': Port number ended with 'O
>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=%20%27:%20Port%20number%20ended%20with%20%27O>
>>> it seems wrong the url, it should be
>>> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_OSGeo_grass.git&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=2s0FIt9ZZMaEF8dGFczUzV71CeMzJZ3MBNeNaOmhcp4&e=
>>> Any suggestions? I don't want to have to keep forking and cloning
>>> Michael
>>> ciao
>>> Luca
>>> www.lucadelu.org
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.lucadelu.org&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=pAhL9Y2iEzu8CenXO-1i6_H9r36a9CPGOFayiqlOt-c&s=J-tuBuLZelC3fMj79PtkGbfbIHqm9UJf7WBPv8Rc2Ws&e=>
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_grass-2Ddev&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=pAhL9Y2iEzu8CenXO-1i6_H9r36a9CPGOFayiqlOt-c&s=vmKu_nbFyMp8-vFqrUtWz3sYsx4svN1aErBtV22T72I&e=>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/d5cc529a/attachment-0001.html>
