[GRASS-dev] [GRASS GIS] #3487: vector digitizer unstable
trac at osgeo.org
Mon Mar 23 04:19:39 PDT 2020
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.8.3
Component: wxGUI | Version: 7.2.2
Resolution: | Keywords: digitizer, ctypes
CPU: OSX/Intel | Platform: MacOSX
Comment (by nila):
I have been able to track the origin of the problem. It is python ctypes
related.
(lldb) bt
* thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS
(code=1, address=0x100000019)
* frame #0: 0x000000010d4ca8f2
Python`_PyObject_IsFreed(op=0x0000000100000001) at object.c:423:56
frame #1: 0x000000010d4caa42
Python`_PyObject_Dump(op=0x0000000100000001) at object.c:450:9
frame #2: 0x000000010d4ced5a
Python`_Py_ForgetReference(op=0x0000000124b5c970) at object.c:1950:9
frame #3: 0x000000010d4c95d5 Python`_Py_Dealloc(op=0x0000000124b5c970)
at object.c:1973:5
frame #4: 0x00000001175a8605 _ctypes.cpython-37dm-
darwin.so`_ctypes_callproc(pProc=(libgrass_vector.7.9.dylib`Vect_open_update
at open.c:641), argtuple=0x0000000115e64960, flags=4353,
argtypes=0x0000000120895ce0, restype=0x00007fcd62120e40,
checker=0x0000000000000000) at callproc.c:1226:9
frame #5: 0x0000000117598f23 _ctypes.cpython-37dm-
darwin.so`PyCFuncPtr_call(self=0x0000000120893560,
inargs=0x0000000115e64960, kwds=0x0000000000000000) at _ctypes.c:4025:14
frame #6: 0x000000010d44763a
Python`_PyObject_FastCallKeywords(callable=0x0000000120893560,
stack=0x00007fcd64629840, nargs=3, kwnames=0x0000000000000000) at
call.c:199:18
The call (starting from
[https://github.com/OSGeo/grass/blob/c33bb5ecd4fe52f6406ae4ddffd316d80435f6fb/gui/wxpython/vdigit/wxdisplay.py#L1021
wxdisplay.py#L1021]) to GRASS c code function `Vect_open_update()` returns
successfully, but ctypes' `_ctypes_callproc()` internal cleanup at
[https://github.com/python/cpython/blob/d7c567b08f9d7d6aef21b881340a2b72731129db/Modules/_ctypes/callproc.c#L1226
callproc.c#L1226] hits bad memory access.
I'm not sure yet whether the issue is fixable within GRASS or if it has to
be dealt with upstreams.
Sidenote: I made a python script calling only the relevant code without
the gui with the same result (segfault), this eliminates the possibility
of event (binding) related effects.
Additionally, the reported issue on "Expecting 825x586 image but got
825x622 image." [https://trac.osgeo.org/grass/ticket/3487#comment:19
comment:19] is an equally critical but a separate one to the originally
reported issue. The following seems to fix this latter issue (but I'd wait
to PR this before a solution for both of them can be presented):
diff --git a/gui/wxpython/mapdisp/toolbars.py
b/gui/wxpython/mapdisp/toolbars.py
index e8b08ad79..9bce3a0ef 100644
--- a/gui/wxpython/mapdisp/toolbars.py
+++ b/gui/wxpython/mapdisp/toolbars.py
@@ -233,6 +233,7 @@ class MapToolbar(BaseToolbar):
"""Select / enable tool available in tools list
tool = event.GetSelection()
+ self.parent.mapWindowProperties.autoRender = False
if tool == self.toolId['2d']:
self.ExitToolbars()
@@ -253,6 +254,8 @@ class MapToolbar(BaseToolbar):
self.ExitToolbars()
self.parent.AddRDigit()
+ self.parent.mapWindowProperties.autoRender = True
def OnAnalyze(self, event):
"""Analysis tools menu
Ticket URL: <https://trac.osgeo.org/grass/ticket/3487#comment:24>
