[GRASS-dev] ZSTD compression error on Windows
Martin Landa landa.martin at gmail.com
Fri May 1 03:46:17 PDT 2020
I have problem to read raster data created on Linux machine.
With the same data I am getting on Windows error below.
WARNING: ZSTD compression error -14: Unsupported frame parameter
ERROR: Error uncompressing fp raster data for row 30 of <MASK>: error code -1
But ZSTD seems to be enabled on Windows...
C:\>g.version -b
GRASS 7.9.dev (2020)
 ./configure  --host=x86_64-w64-mingw32 '--with-libs=C:\OS3944~1/lib'
--with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
--prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
--includedir=/c/OSGeo4W64/include --without-x --with-cxx
--enable-shared --enable-largefile --with-fftw --with-freetype
--with-freetype-includes=/mingw64/include/freetype2
--with-proj-share=/c/OSGeo4W64/share/proj
--with-proj-includes=/c/OSGeo4W64/include
--with-proj-libs=/usr/src/grass79/mswindows/osgeo4w/lib
--with-postgres --with-postgres-includes=/c/OSGeo4W64/include
--with-postgres-libs=/usr/src/grass79/mswindows/osgeo4w/lib
--with-gdal=/usr/src/grass79/mswindows/osgeo4w/gdal-config
--with-geos=/usr/src/grass79/mswindows/osgeo4w/geos-config
--with-sqlite --with-sqlite-includes=/c/OSGeo4W64/include
--with-sqlite-libs=/usr/src/grass79/mswindows/osgeo4w/lib --with-regex
--with-nls --with-zstd --with-odbc --with-cairo --with-opengl=windows
--with-bzlib --with-liblas=/usr/src/grass79/mswindows/osgeo4w/liblas-config
Any idea? Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
