[GRASS-dev] ZSTD compression error on Windows
Helmut Kudrnovsky
hellik at web.de
Fri May 1 04:15:40 PDT 2020
Helmut Kudrnovsky wrote
> Martin Landa wrote
>> Hi,
>> I have problem to read raster data created on Linux machine.
>> With the same data I am getting on Windows error below.
>> WARNING: ZSTD compression error -14: Unsupported frame parameter
>> ERROR: Error uncompressing fp raster data for row 30 of
> <MASK>
>> : error code -1
>> But ZSTD seems to be enabled on Windows...
>> C:\>g.version -b
>> GRASS 7.9.dev (2020)
>> ./configure --host=x86_64-w64-mingw32 '--with-libs=C:\OS3944~1/lib'
>> --with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
>> --prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
>> --includedir=/c/OSGeo4W64/include --without-x --with-cxx
>> --enable-shared --enable-largefile --with-fftw --with-freetype
>> --with-freetype-includes=/mingw64/include/freetype2
>> --with-proj-share=/c/OSGeo4W64/share/proj
>> --with-proj-includes=/c/OSGeo4W64/include
>> --with-proj-libs=/usr/src/grass79/mswindows/osgeo4w/lib
>> --with-postgres --with-postgres-includes=/c/OSGeo4W64/include
>> --with-postgres-libs=/usr/src/grass79/mswindows/osgeo4w/lib
>> --with-gdal=/usr/src/grass79/mswindows/osgeo4w/gdal-config
>> --with-geos=/usr/src/grass79/mswindows/osgeo4w/geos-config
>> --with-sqlite --with-sqlite-includes=/c/OSGeo4W64/include
>> --with-sqlite-libs=/usr/src/grass79/mswindows/osgeo4w/lib --with-regex
>> --with-nls --with-zstd --with-odbc --with-cairo --with-opengl=windows
>> --with-bzlib
>> --with-liblas=/usr/src/grass79/mswindows/osgeo4w/liblas-config
>> Any idea? Thanks, Martin
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
>> grass-dev mailing list
>> grass-dev at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> Maybe different zstd versions in linux and windows? Maybe we should update
> zstd in osgeo4w?
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev at .osgeo
In OSGeo4W we have 1.3.2
(http://download.osgeo.org/osgeo4w/x86_64/release/zstd/),
Actual version is 1.4.4.
AFAIR there are some zstd configure options, maybe some not default
activated here or there?
best regards
Helmut
