[GRASS-dev] Unable to install grass-core on debian 10 (buster)
aborruso
aborruso at gmail.com
Mon May 18 05:26:17 PDT 2020
I would like to run some grass processes via sh scripts.
After running "sudo apt-get install grass-core", I have:
"The following packages have unmet dependencies:
grass-core : Depends: libgdal26 (>= 2.2.0) but it is not going to be
installed
Depends: libnetcdf18 (>= 3.6.1) but it is not going to be
installed
Depends: libpdal-base10 (>= 1.8.0) but it is not going to be
installed
Recommends: gdal-bin but it is not going to be installed
E: Unable to correct problems, you have held broken packages."
If I run "sudo apt-get install libgdal26 libnetcdf18 libpdal-base10", I
have:
libgdal26 : Depends: libhdf5-103-1 but it is not going to be installed
libnetcdf18 : Depends: libhdf5-103-1 but it is not going to be installed
Depends: libhdf5-hl-100 but it is not going to be installed
And finally if I run "sudo apt-get install libhdf5-103-1 libhdf5-hl-100" I
have:
libhdf5-103-1 : Breaks: libhdf5-103 but 1.10.4+repack-11 is to be installed
libhdf5-hl-100 : Conflicts: libhdf5-103 (< 1.10.5) but 1.10.4+repack-11 is
to be installed
Do you have some tips to solve these?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
