[GRASS-dev] Call for changes in the Python library
Vaclav Petras wenzeslaus at gmail.com
Fri Oct 2 20:14:38 PDT 2020
Hi Laurent,
On Fri, Sep 25, 2020 at 2:53 PM Laurent C. <lrntct at gmail.com> wrote:
> From my experience, the temporal framework is rather quirky, and might be
> in need of refactoring to fix some of those quirkiness (see for example
> https://github.com/OSGeo/grass/issues/629).
> Most of it might be done without breaking the API, but the new major
> version could be an opportunity to break things for the better.
This sounds great. There are a lot of tests in place, so that's a good
starting point. I would be happy to discuss the details if you can work on
the changes. Having a bigger flexibility with mapsets makes sense to me.
Best,
Vaclav
PS: Check a recent PR on GitHub for init/connect.
> Cheers,
> Laurent
> Le jeu. 24 sept. 2020 à 21:29, Vaclav Petras <wenzeslaus at gmail.com> a
> écrit :
>> Dear all,
>> Now would be a great time to do any large or small changes in the Python
>> library. Let's discuss these. For example, there was a talk about more
>> clear splitting of the ctypes dependent and independent code in
>> grass.pygrass, about moving the library to a different place, there is the
>> new grass.grassdb subpackage, PEP8/Black/Flake8, ... Is there anything
>> *you* see as a priority for 8.0? Is there anything you can do before 8.0?
>> Let's coordinate here.
>> Best,
>> Vaclav
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20201002/052c46bd/attachment.html>
