[GRASS-dev] Compile grass addon
ming han
dustming at gmail.com
Fri Sep 4 19:43:12 PDT 2020
Hi Everyone
Hope this email finds you well.
I can generate GRASS addon executable by commands in the following
sections.
But when I load it in GRASS, it reports the following error. at the
sametime I can successfully load other GRASS executable like r.what
"dyld: Library not loaded: @rpath/libgrass_gis.dylib
Referenced from:
/Applications/QGIS3.14.app/Contents/MacOS/grass/bin/r.stream.basins
Reason: image not found
Abort trap: 6"
Thanks
Ming
gcc -g -O2 -I/Applications/QGIS3.14.app/Contents/MacOS/grass/include
-I/Library/Frameworks/GDAL.framework/Versions/3.1/Headers
-I/Library/Frameworks/GEOS.framework/Versions/3C/unix/include
-DPACKAGE=\""grassmods"\"
-DRELDIR=\"grass_addon/raster/r.stream.basins\" -o basins_fill.o -c
basins_fill.c
-DRELDIR=\"grass_addon/raster/r.stream.basins\" -o basins_inputs.o -c
basins_inputs.c
-DRELDIR=\"grass_addon/raster/r.stream.basins\" -o io.o -c io.c
-DRELDIR=\"grass_addon/raster/r.stream.basins\" -o main.o -c main.c
gcc -L/Applications/QGIS3.14.app/Contents/MacOS/grass/lib -o
./basins_fill.o ./basins_inputs.o ./io.o ./main.o -lgrass_gis.7.8
-lgrass_raster.7.8 -lgrass_segment.7.8 -lgrass_vector.7.8
-lgrass_dbmiclient.7.8 -lgrass_dbmibase.7.8
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200904/5c3db89a/attachment.html>
