[GRASS-dev] [release planning] GRASS GIS 7.8.6
Markus Neteler
neteler at osgeo.org
Tue Apr 13 05:22:15 PDT 2021
(moved back into email thread)
On Mon, Apr 12, 2021 at 9:16 PM Helmut Kudrnovsky <hellik at web.de> wrote:
> > Markus:
> >Open questions for anyone with Windows (Helli? Others?):
> >- Is g.extension failing for all add-ons or only for a few? A new
> >blocker or not?
> winGRASS g.extension is failing for some of the addons where some encoding issues pops up.
> but see https://github.com/OSGeo/grass/pull/1496#issuecomment-812447963
> >manually set PYTHONUTF8 in C:\OSGeo4W64\apps\grass\grass79\etc\env.bat
> >set PYTHONUTF8=1
> >set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python3.exe
> >then
> > g.extension extension=i.fusion.hpf
> > Downloading precompiled GRASS Addons <i.fusion.hpf>...
> > Fetching <i.fusion.hpf> from <http://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/i.fusion.hpf.zip> (be patient)...
> > Updating extensions metadata file...
> > Updating extension modules metadata file...
> > WARNING: No metadata available for module 'constants'.
> > WARNING: No metadata available for module 'high_pass_filter'.
> > ERROR: Unable to read manual page: [Errno 2] No such file or directory: 'C:\\Users\\youruser\\AppData\\Roaming\\GRASS7\\addons\\docs\\html\\constants.html'
Well, does the file exist?
> >at least no fileinput.FileInput error anymore
> g.extension works then with these encoding issue addons
> this is based upon https://docs.python.org/3/using/windows.html#utf-8-mode
> > Windows still uses legacy encodings for the system encoding (the ANSI Code Page). Python uses it for the default encoding of text files (e.g. locale.getpreferredencoding()).
> > This may cause issues because UTF-8 is widely used on the internet and most Unix systems, including WSL (Windows Subsystem for Linux).
> > You can use UTF-8 mode to change the default text encoding to UTF-8.
> I've tested a bit locally, g.extension works then (beside https://github.com/OSGeo/grass/issues/1499 , though that's a minor issue as all nested addons and helper libs are working, just a nasty warning ); (localized) GUI is mostly working.
> though I have no idea if there are any possible side effects with set PYTHONUTF8=1 ....
> maybe Anna, Maris have some ideas?
Unfortunately I don't...
> should we activate it in master and see what CI test are reporting?
Might be an option to find out.
> kind regards
> Helmut
ciao,
Markus
