[GRASS-dev] Moving to Black for Python formatting
Vaclav Petras wenzeslaus at gmail.com
Wed Apr 14 18:32:11 PDT 2021
PR 1527 introduces Black to wxGUI code. Open PRs will likely need to be
updated before merging.
https://github.com/OSGeo/grass/pull/1527
On Fri, Feb 26, 2021 at 11:24 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Feb 26, 2021 at 7:01 AM Luca Delucchi <lucadeluge at gmail.com>
> wrote:
>> On Fri, 26 Feb 2021 at 06:00, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> > All this applies to core repo, not the grass-addons repo. Ideas and
>> volunteers are welcome.
>> Do you have any suggestions on how to proceed to grass-addons?
>> Did you just run blake inside a folder or did you do something more?
> Here is what I did:
> * Applied Black.
> * Added pyproject.toml with configuration for Black.
> * Modified Flake8 rules.
> * Added a Black GitHub workflow.
> The application of Black can use some touches here and there. You need to
> use the same Black version. You may want to modify some lines before and
> after (I did just things I caught for one reason or another - you cannot
> review all changes). You may run Flake8 to check for long lines after you
> applied Black and see if there is something you can resolve. I did separate
> PRs for different directories, but that was because the codebases are
> different in each and also a little bit to minimize conflicts with other
> PRs (these should not be an issue with grass-addons repo). Commit per
> directory, but then squashing them when merging the PR might be a good
> approach for grass-addons.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210414/4b2a286e/attachment.html>
