[GRASS-dev] Management of signature files
Vaclav Petras
wenzeslaus at gmail.com
Fri Apr 30 14:00:45 PDT 2021
Hi Maris,
Here are my thoughts about the signature files.
On Tue, Apr 27, 2021 at 2:44 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> #2 A variation of #1. Add a separate signature file management tool
> (i.signatures?). ... one has to remember to use a
> special module that differs from the rest (vect, raster, raster3d)...
> #4 A variation of #3. Change signature storage to
> "<MAPSET>/signatures/<signature file name>.<SIG_TYPE>" Pro: easy to
> add to g.* tools with element syntax "<name>.<SIG_TYPE>(@<MAPSET>)".
> Con: needs special handling in GUI (show items matching SIG_TYPE);
> element syntax differs from other data elements.
I'm for using file extensions and a separate set of tools, so combination
of your #4 and #2.
As you say, /signatures/subdir/file extends the basic GRASS locatio
structure anyway. Extensions are a general concept which we will just apply
here. It could work for other things as well. You could have, e.g.,
<MAPSET>/vector/<name>/hist.yaml. I don't know how much to show the type
(extension) in case of signatures. I think it depends on how much the tools
will deal with signatures of the wrong type for them. Having extensions in
place may help when you decide you want standalone signatures outside of
GRASS location.
A separate set of tools may be actually less confusing, but that really
depends on what each user expects from g.list. Should everything be handled
by g.list, e.g., tools installed from addons? Of course not. If you need to
work with signature files, you will get to a list of necessary tools
somewhere. If you don't, you are not distracted by that.
As an alternative to both extensions and subdirectories, you could change
the format to something which each tool can easily recognize as something
readable or unreadable like having a first line "format: sigset". Each tool
needs to write it and check it, but from a file management perspective it
all formats are the same.
Whichever path you take, I like that you are revising this!
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210430/9d6e2bc4/attachment.html>
