[GRASS-dev] Renaming master branch to main branch
Veronica Andreo
veroandreo at gmail.com
Wed Aug 25 12:32:04 PDT 2021
Well, since addon repo structure changed and master is no longer used as
base branch, but grass7, and eventually it will be grass8, the name change
does not seem very relevant or urgent there, no?
Not strong opinion though
Vero
El mié, 25 ago 2021 a las 21:21, Nikos Alexandris (<nik at nikosalexandris.net>)
escribió:
> Thank you Vaclav.
> Will the same name-update happen for the addons?
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210825/8a08c808/attachment.html>
