[GRASS-dev] No more compiler warnings
Vaclav Petras
wenzeslaus at gmail.com
Thu Aug 26 19:25:16 PDT 2021
Awesome!
I'm not suggesting to do it right now, but for the future, what do you
think about adding more warnings/errors? There is, for example,
-Wunused-result or -Wunused-but-set-variable which we have in the code.
warning: ignoring return value of ‘fread’, declared with attribute
warn_unused_result [-Wunused-result]
warning: variable ‘mapone’ set but not used [-Wunused-but-set-variable]
Many thanks,
Vaclav
On Thu, Aug 26, 2021 at 8:50 PM Anna Petrášová <kratochanna at gmail.com>
wrote:
> That's great, thank you and others involved for working on this, it is an
> impressive amount of work!
> Anna
> On Thu, Aug 26, 2021 at 4:22 PM Nicklas Larsson via grass-dev <
> grass-dev at lists.osgeo.org> wrote:
>> Hi all!
>> At the beginning of this year, compiling GRASS raised a very high number
>> of compiler warnings. For example with GCC there were about 140 and with
>> Clang about 300 warnings. This was reported with GitHub issue #1247 [1].
>> Since then these warnings has been addressed in a number of PRs. Today we
>> have reached the point where there are no warnings at all (!) for either
>> GCC and Clang (with default settings) on the main branch.
>> To keep this level of warning frequency to zero, the compiler flag
>> -Werror has been added to the GitHub "GCC C/C++ standards check" CI builds.
>> This will treat a compiler warning as an error, and will cause the build to
>> fail.
>> For those who have a PR in the pipeline affecting C or C++ code, should
>> consider making a rebase to main (or otherwise trigger a CI check) before
>> merging.
>> Cheers,
>> Nicklas
>> [1] https://github.com/OSGeo/grass/issues/1247
>> grass-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210826/5213347e/attachment.html>
