[GRASS-dev] minor tweak to new website
Vaclav Petras wenzeslaus at gmail.com
Fri Jan 15 20:35:24 PST 2021
On Fri, Jan 15, 2021 at 4:12 PM Michael Barton <Michael.Barton at asu.edu>
wrote:
> You are correct about the redundancy. I was trying to make the change as
> minor as possible. A somewhat better listing would be
> *GRASS GIS 7.8.5 (current stable)*
> *GRASS GIS 7.6.1 (legacy) [change from “old”]*
> *GRASS GIS 7.9 (preview) [“development” is OK, but “preview” sounds more
> inviting for use]*
+1 for legacy and especially preview, I like that a lot!
I'm unsure about "current stable". It seems like one of the works might be
enough. I thought stable should be enough, but PostgreSQL actually uses
Current in documentation just be itself. Isn't there a noun "release"
implied in each of those? Aren't all releases stable unless noted
otherwise? Isn't then "stable" redundant? Anyway, I like the proposal even
as is.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210115/6df62781/attachment.html>
