[GRASS-dev] [GRASS-user] compare a DCELL and FCELL question
Micha Silver tsvibar at gmail.com
Sun Jan 24 00:29:33 PST 2021
Is there some reason that you expect the rasters to be the same? Maybe
begin by posting the outputs of `r.info` for both rasters, and what
command you used to compare them?
On Sun, Jan 24, 2021 at 6:13 AM ming han <dustming at gmail.com> wrote:
> Hi Everyone
>     I tried to compare if grids in two rasters are the same, one raster is FCELL and another raster is DCELL. I got different result  when I int both raster first before comparing them; and when I float() both raster first before I comparing them
> Is there any reason for this?
> Thanks
> Ming
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ
Sde-Boker Remote Sensing Lab
cell: +972 (52) 3665918
