[GRASS-dev] [GRASS-user] compare a DCELL and FCELL question
Zoltan
zoltans at geograph.co.za
Sun Jan 24 08:12:41 PST 2021
Is it important to cross-post this discussion on both dev and user lists?
Regards,
Zoltan
On 2021-01-24 17:56, Markus Metz wrote:
> Trying to answer the original question: with a DCELL map
> "cat1_acc_riv" and a FCELL map "cat1_minacc", why is
> "float(cat1_acc_riv) == float(cat1_minacc)" not equal to
> "int(cat1_acc_riv) == int(cat1_minacc)" ?
> int truncates to integer while float converts to single precision
> floating point. E.g. with cat1_acc_riv = 1.1 and cat1_minacc = 1.9,
> "float(cat1_acc_riv) == float(cat1_minacc)" becomes "1.1 == 1.9"
> whereas "int(cat1_acc_riv) == int(cat1_minacc)" becomes "1 == 1", thus
> the results are different.
> Another reason for possible differences is that float can only
> represent max 7 decimal digits. E.g. float(194320567) becomes
> 194320560 but int(194320567) preserves the value 194320567.
> Thus the safest is to cast everything to the type with the highest
> precision. In this case with FCELL and DCELL, use
> "double(cat1_acc_riv) == double(cat1_minacc)" or even better the
> suggestion of Markus N.
> Markus M
> On Sun, Jan 24, 2021 at 3:51 PM ming han <dustming at gmail.com
> <mailto:dustming at gmail.com>> wrote:
> > Hi Markus and Micha
> > I am just trying to find grids have the same values in these
> two rasters, I will try the threshold approach.
> > Thanks
> > Ming
> > Markus Neteler <neteler at osgeo.org <mailto:neteler at osgeo.org>>
> 于2021年1月24日周日 上午6:58写道:
> >> Hi Ming,
> >> On Sun, Jan 24, 2021 at 10:49 AM ming han <dustming at gmail.com
> >> > Hi Micha
> >> > Many thanks for your reply.
> >> > Here is the command I am using:
> >> > if(float(cat1_acc_riv) == float(cat1_minacc), str_r, null())
> >> > The str_r is a CELL raster. the result is different when I
> change it to:
> >> > if(int(cat1_acc_riv) == int(cat1_minacc), str_r, null())
> >> Note that numerical "equality" is better tested with a threshold test
> >> against the map pixel difference.
> >> As the threshold, we use GRASS_EPSILON which is defined as 1.0e-15.
> >> Hence the test needs to be implemented in a different way, i.e. by
> >> using an epsilon.
> >> Essentially something like this:
> >> if(fabs(map_A - map_B) <= 1.0e-15, ... )
> >> In your case (untested):
> >> r.mapcalc diffepsilon = if( abs( map_A - map_B) <= 1.0e-15, str_r ,
> null())
> >> See related discussions here: [1], [2] and elsewhere.
> >> [1] Comment by Glynn:
> https://trac.osgeo.org/grass/ticket/2854#comment:9
> <https://trac.osgeo.org/grass/ticket/2854#comment:9>
> >> [2] Comment by Glynn:
> https://lists.osgeo.org/pipermail/grass-user/2015-October/073200.html
> <https://lists.osgeo.org/pipermail/grass-user/2015-October/073200.html>
> >> Best,
> >> Markus
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
> <https://lists.osgeo.org/mailman/listinfo/grass-dev>
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210124/bcbf95a8/attachment.html>
