[GRASS-dev] r.to.rast3 error messages
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jul 19 02:15:43 PDT 2021
On Mon, Jul 19, 2021 at 4:14 AM Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Sun, Jul 18, 2021 at 5:57 AM Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> Hi devs,
>> When running r.to.rast3 with as input two integer maps:
>> r.to.rast3 input=soc_0_5cm_mean,soc_5_15cm_mean output=test
>> I am getting the following two warnings:
>> WARNING: G__open_misc(read): Unable to open
>> '/home/paulo/grassdb/Schijndel/soils/cell_misc/soc_5_15cm_mean/nullcmpr':
>> Too many open files
>> WARNING: G__open(read): Unable to open
>> '/home/paulo/grassdb/Schijndel/soils/cellhd/soc_5_15cm_mean': Too many open
>> files
>> and the error message:
>> ERROR: Error reading reclass file for raster map <soc_5_15cm_mean at soils>
>> I am really not sure what these messages are about. The warning messages
>> do not seem to make sense, I am only using two files as input. I do not
>> understand the error message either, or what the reclass is referring to.
>> Any idea, is this a bug I should report, or something I am doing wrong?
> Any chance you are running something else at the same time? Generally,
> there is a limit on the number of open files (see e.g. r.series man page).
I thought of that, but the same error occurred after running the function
as first thing after restarting grass gis.
>> Mvg.
>> Paulo
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210719/c44c5de5/attachment.html>
