[GRASS-dev] d.mon segfaulting on debian/ubuntu custom/docker
Luca Delucchi lucadeluge at gmail.com
Tue May 4 11:55:06 PDT 2021
Il mar 4 mag 2021, 20:30 Jachym Cepicky <jachym.cepicky at gmail.com> ha
scritto:
> Hi,
Hi Jackym
> running
> d.mon start=cairo
> d.mon stop=cairo
> will lead to Segmentation fault.
> same for
> d.mon start=wx0
> or
> d.mon start=png
> I'm using GRASS 7.8.2, official packages from Ubuntu 20.04, nothing fancy.
> When tried docker image
> docker run --rm -ti -v $(pwd):/data/ -v $(pwd)/grassdata:/grassdata
> mundialis/grass-py3-pdal:stable-ubuntu
> it was segfaulting too! so was debian
> when trying -alpine , no problem (or did not seem to be)
> Any hint, what could be the reason?
No idea, just a silly question...
Did you try rendering any maps?
With cairo I usually set the output variable...
I'm using "d.mon start=cairo out=/path/to/file" daily and I have no
problem.
> Jachym
Ciao
Luca
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210504/1825dff9/attachment.html>
