[GRASS-dev] Fwd: [Bug] Fix currently ignored Flake8 warnings #1522
Shubham Swati Prasad
h20200049 at goa.bits-pilani.ac.in
Thu May 6 08:47:30 PDT 2021
---------- Forwarded message ---------
From: Shubham Swati Prasad <h20200049 at goa.bits-pilani.ac.in>
Date: Thu, 6 May 2021, 19:04
Subject: Re: [GRASS-dev] [Bug] Fix currently ignored Flake8 warnings #1522
To: Markus Neteler <neteler at osgeo.org>
Respected sir,
I have cloned the repository and after that I'm totally stuck. I don't know
how to proceed further. I want to start working on the bug as soon as
possible. Kindly guide me.
Regards
Shubham Swati
On Thu, Apr 22, 2021 at 11:20 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi Shubham Swati,
> On Thu, Apr 22, 2021 at 6:08 PM Shubham Swati Prasad
> <h20200049 at goa.bits-pilani.ac.in> wrote:
> > Respected sir/mam,
> > This is with reference to the bug mentioned in the subject line. I had
> commented on GitHub regarding this bug, that I'm new to open source
> projects and coding, but I'm interested to work on it.
> First of all, welcome here!
> > One of the respected members replied and told me to first clone and
> compile the code. I have cloned the code. After that, I executed the
> following two commands:
> > git remote add upstream https://github.com/OSGeo/grass
> > git remote -v
> > After this can I directly start editing the code? Or compilation is
> still required? I am new to this and I'm not able to understand the
> compilation. I am using Ubuntu 20.04 Kindly help me with this.
> Your questions are right. When looking at this document (which I
> initially thought to send as an answer) I see the documentation gap
> therein:
> https://github.com/OSGeo/grass/blob/master/CONTRIBUTING.md#first-time-setup
> NOTE TO Devs: We should expand the "first time setup" part and add
> some hints concerning the source code compilation.
> Here my attempt to
> General concept:
> GRASS GIS is written in a small (and happy) mixture of programming
> languages. The major part of the source code is written in C language
> which requires a compiler to be turned into executables ("binaries").
> About 30% is written in Python which is an interpreted language, hence
> "just" needs the Python program to be installed.
> Now, to turn the source code package into an installed binary package,
> the so-called "compilation" is needed. While the source code consists
> of thousands of C and Python files (plus HTML documentation), the
> "Makefile" system included does the job of compiling the source code
> in the right order, generating the manual pages, etc.
> In essence, the way of installation of the compiler tools + Python
> depends on the operating system. To facilitate this, we have collected
> copy-paste instructions for most operating systems in our Wiki:
> https://grasswiki.osgeo.org/wiki/Compile_and_Install
> What's next:
> Please check the Wiki page (hope the attempt of an intro above helps;
> pls ask otherwise here in the list) and give it a try.
> I am happy to add an extra section to the CONTRIBUTING.md file (or
> another place, if the devs prefer) to fill the gap in the document.
> Best,
> Markus
> Markus Neteler, PhD
> https://www.mundialis.de - free data with free software
> https://grass.osgeo.org
> https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210506/e8f345e9/attachment.html>
