[GRASS-dev] ParallelModuleQueue freezes...
Luca Delucchi lucadeluge at gmail.com
Wed May 26 06:59:25 PDT 2021
On Wed, 26 May 2021 at 15:13, Stefan Blumentrath
<Stefan.Blumentrath at nina.no> wrote:
> Thanks, Markus.
> Seems that the ParallelModuleQueue itself works if it is fed with Module objects, but not if MultiModule objects are put into the queue...
> So, I believe I am struggling with the same issue as Luca:
> https://github.com/OSGeo/grass-addons/pull/523#issue-629160914
probably yes
> Can it be that returns of the MuliModule should be different? If I understand the source code [1]  correctly, Module returns "self" (a Module object) while MultiModule returns "None". Can that be the root cause?
it seems to me that MultiModule returns "None" when it finish
otherwise return self.p (a Process instance)
> Any help is much appreciated...
same for my side :-)
> Cheers
> Stefan
> 1: https://grass.osgeo.org/grass79/manuals/libpython/_modules/pygrass/modules/interface/module.html#MultiModule
ciao
Luca
www.lucadelu.org
