[GRASS-dev] ParallelModuleQueue freezes...
Anna Petrášová kratochanna at gmail.com
Fri May 28 07:32:42 PDT 2021
Which Python do you have? The test is running just fine for me with 3.6.
On Thu, May 27, 2021 at 2:19 AM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> The combination ParallelModuleQueue and MultiModule is used in
> t.rast.neighbors:
> https://github.com/OSGeo/grass/blob/master/temporal/t.rast.neighbors/t.rast.neighbors.py
> The testsuite of that module is deactivated for Python > 2.
> https://github.com/OSGeo/grass/blob/master/temporal/t.rast.neighbors/testsuite/test_neighbors.py
> If you activate it by commenting out line 15. You will see the behavior...
> Thanks for looking into this!
> Cheers
> Stefan
> -----Original Message-----
> From: Luca Delucchi <lucadeluge at gmail.com>
> Sent: torsdag 27. mai 2021 06:07
> To: Anna Petrášová <kratochanna at gmail.com>
> Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; GRASS developers
> list <grass-dev at lists.osgeo.org>
> Subject: Re: [GRASS-dev] ParallelModuleQueue freezes...
> On Thu, 27 May 2021 at 04:07, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > Could you provide an example that is failing? The doctests are running
> for me. I spent some time fixing it a couple months ago. I use Python 3.6,
> I wonder if newer Python would cause some issues.
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&data=04%7C01%7C%7Cb35d171402fc441dfd7508d920c4edc3%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637576852445926368%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=a8JVAn3N77HwODX5FguDQjxI4PbUbkN4ZicO4RYuHqo%3D&reserved=0
> line 544, the commented lines are not working for me..
> If you want to try t.vi just comment line 543 and uncomment the following
> lines..
> > Anna
> ciao
> Luca
> https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&data=04%7C01%7C%7Cb35d171402fc441dfd7508d920c4edc3%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637576852445936369%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=RWkoI4e%2BbY9%2F5Ow%2BOMqPtEgHGS2BqWRL4pes%2B%2B5T%2BNA%3D&reserved=0
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210528/526f4a4a/attachment.html>
