[GRASS-dev] [gdal-dev] Moving GDAL GRASS driver in a dedicated repository ?
Markus Metz markus.metz.giswork at gmail.com
Tue Nov 23 12:50:51 PST 2021
Hi Even,
IMHO it has been a bit of a luxury that the GDAL GRASS driver was allowed
to exist as a regular GDAL supported format within frmts/grass. With every
new release of GDAL, you (the GDAL maintainers) also released a separate
new GDAL GRASS driver which was really nice of you!
Considering the workaround for this circular dependency, I agree that a
dedicated repository makes sense.
I personally don't use the GDAL GRASS driver at all (I just try to maintain
it), but I am aware that a number of projects use the GDAL GRASS driver.
Feedback from any affected projects would be helpful.
Markus M
On Thu, Nov 18, 2021 at 7:13 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> (writing to both GDAL and GRASS lists)
> Working on the transition to CMake as the GDAL build system, the
> particular status of the GRASS driver in GDAL raised my attention.
> (The following is based on my understanding. It has been ages since I
> didn't try this...)
> This driver is a bit odd in the sense that there's a cyclic dependency
> to work around, as GRASS links to GDAL , but the GDAL GRASS driver needs
> to be linked against GRASS.
> So the usual procedure is:
> - build GDAL without the GRASS driver
> - build GRASS against GDAL
> - build the GDAL GRASS driver from the separate gdal-grass tarball that
> GDAL distributes along its main tarball.
> With the current GDAL autoconf build system, there's also the
> possibility to rebuild GDAL with the GRASS driver builtin in libgdal,
> but that's a bit odd, since you need to make sure that this new libgdal
> is the one that GRASS will link against at runtime, otherwise chaos will
> ensure. I'm not sure if that's used. This is typically something I would
> *not* want to support in the new GDAL cmake build.
> All in all, given the particular nature of that driver, I believe it
> would be better in a dedicated repository, with its standalone build
> scripts, whose initial version could be just the ones of
> https://github.com/OSGeo/gdal/tree/master/frmts/grass/pkg, or evolve to
> CMake or whatever the maintainers of that driver would prefer. I believe
> this would make the situation clearer.
> Opinions ? and people interested in setting up that dedicated repository ?
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20211123/c3577845/attachment.html>
