[GRASS-dev] addon r.area.createweight not available?
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Tue Oct 19 00:39:54 PDT 2021
Hi Charlotte,
It seems, the issue is that the Makefile is named 'Makefile.txt'.
So it is not executed and the addon is not built.
If you rename it, the addon should become available with the next (nightly) build...
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of FLASSE Charlotte via grass-dev
Sent: tirsdag 19. oktober 2021 09:21
To: grass-dev at lists.osgeo.org
Subject: [GRASS-dev] addon r.area.createweight not available?
Dear all,
I was expecting the add-on r.area.createweight to be included with the 7.8.6 release of GRASS, but it does not appear either in the 'new addons' list on the summary of changes<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftrac.osgeo.org%2Fgrass%2Fwiki%2FRelease%2F7.8.6-News&data=04%7C01%7CStefan.Blumentrath%40nina.no%7Ce1ad1f15760c4a3ab42108d992d0f5ef%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637702248450407118%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=VXG4kM8PvMcRF%2BuSR4yXnTpUeQmPFOw7crXOD5pVgEE%3D&reserved=0> page, nor is it possible to add with g.extension.
Was wondering what the issue might be ?
Thanks,
Charlotte
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20211019/6a79c9c2/attachment.html>
