[GRASS-dev] hi
Veronica Andreo
veroandreo at gmail.com
Mon Aug 1 09:43:21 PDT 2022
Hello Daniel,
IIRC, I suggested using something similar to what wowchemy (former hugo
academic) has, but the path chosen was different. Paulo, also made a
suggestion, but I didn't have the time to try, honestly. I think it's all
in the PRs and probably this issue too:
https://github.com/OSGeo/grass-website/issues/19
Vero
El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
escribió:
> Thanks guys,
> I'm ok with starting on the website.
> About the search, in Hugo website they suggest a couple of methods
> https://gohugo.io/tools/search/ , have those been tried?
> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi Daniel,
>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>> starting with something for the website, we are missing a search engine
>> there. There were a couple of attempts in the past but none of them worked
>> fully as expected. Have a look at the PRs here:
>> https://github.com/OSGeo/grass-website/pulls
>> Best,
>> Vero
>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<wenzeslaus at gmail.com>)
>> escribió:
>>> Hi Daniel,
>>> Welcome. That sounds great. For Python, check this presentation I'm
>>> preparing for FOSS4G where are I describe how to do good PRs which fix
>>> coding standards and the load of tools which can be applied:
>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>> JavaScript at this point means starting with your own idea which may or
>>> may not be what you are looking for. Website is certainly one option.
>>> I would really like to see changes in the documentation (aka HTML manual
>>> pages):
>>> https://grass.osgeo.org/grass83/manuals/
>>> ...but that's certainly "bring your own idea." It likely involves some
>>> HTML and CSS design, but perhaps there is something more functional that
>>> can be done. An alternative to this is migrating to Sphinx first, but
>>> that's just a thought from the past.
>>> Now when I think about it, the full JavaScript checks in Super-Liner are
>>> not enabled, so that's perhaps a small JavaScript task to tackle before
>>> starting a bigger project (that's up to you!).
>>> Let me know if there is any other info which would be helpful.
>>> Best,
>>> Vaclav
>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com> wrote:
>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>> contribute to the project, as I find it really nice. I have experience with
>>>> JS and front end stuff, but also with Python.
>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>> something on the website side?)
>>>> Cheers,
>>>> Daniel
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/0b5db3a7/attachment-0001.htm>
