[GRASS-dev] hi
Veronica Andreo
veroandreo at gmail.com
Mon Aug 1 10:58:35 PDT 2022
Hola Daniel,
None of those at time, but you could open a new discussion in github
(though that is in the main grass repo...)
Vero
El lun., 1 ago. 2022 19:51, Daniel Torres <nobeeakon at gmail.com> escribió:
> thanks Veronica, then I'll try with the ones suggested in Hugo website
> (is there another communication method you guys use, like Slack, discord
> or something like kind of more direct or quick questions and stuff? )
> On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hello Daniel,
>> IIRC, I suggested using something similar to what wowchemy (former hugo
>> academic) has, but the path chosen was different. Paulo, also made a
>> suggestion, but I didn't have the time to try, honestly. I think it's all
>> in the PRs and probably this issue too:
>> https://github.com/OSGeo/grass-website/issues/19
>> Vero
>> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
>> escribió:
>>> Thanks guys,
>>> I'm ok with starting on the website.
>>> About the search, in Hugo website they suggest a couple of methods
>>> https://gohugo.io/tools/search/ , have those been tried?
>>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> Hi Daniel,
>>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>>> starting with something for the website, we are missing a search engine
>>>> there. There were a couple of attempts in the past but none of them worked
>>>> fully as expected. Have a look at the PRs here:
>>>> https://github.com/OSGeo/grass-website/pulls
>>>> Best,
>>>> Vero
>>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<wenzeslaus at gmail.com>)
>>>> escribió:
>>>>> Hi Daniel,
>>>>> Welcome. That sounds great. For Python, check this presentation I'm
>>>>> preparing for FOSS4G where are I describe how to do good PRs which fix
>>>>> coding standards and the load of tools which can be applied:
>>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>>> JavaScript at this point means starting with your own idea which may
>>>>> or may not be what you are looking for. Website is certainly one option.
>>>>> I would really like to see changes in the documentation (aka HTML
>>>>> manual pages):
>>>>> https://grass.osgeo.org/grass83/manuals/
>>>>> ...but that's certainly "bring your own idea." It likely involves some
>>>>> HTML and CSS design, but perhaps there is something more functional that
>>>>> can be done. An alternative to this is migrating to Sphinx first, but
>>>>> that's just a thought from the past.
>>>>> Now when I think about it, the full JavaScript checks in Super-Liner
>>>>> are not enabled, so that's perhaps a small JavaScript task to tackle before
>>>>> starting a bigger project (that's up to you!).
>>>>> Let me know if there is any other info which would be helpful.
>>>>> Best,
>>>>> Vaclav
>>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>>> wrote:
>>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>>> JS and front end stuff, but also with Python.
>>>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>>>> something on the website side?)
>>>>>> Cheers,
>>>>>> Daniel
>>>>>> _______________________________________________
>>>>>> grass-dev mailing list
>>>>>> grass-dev at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/50be73b6/attachment.htm>
