[GRASS-dev] hi
Vaclav Petras wenzeslaus at gmail.com
Mon Aug 1 11:56:36 PDT 2022
There is no difference in discussing things in the PR or issue versus in a
Discussion in terms of notifications, no? If it is about development, it
should be part of this mailing list or the PRs/issues in the relevant repo.
I don't see what Discussion would add here. ...that's of course different
from considering the more "chatty" channels.
On Mon, 1 Aug 2022 at 14:17, Daniel Torres <nobeeakon at gmail.com> wrote:
> Venga, muchas gracias Veronica.
> Nice, thanks, I'll open a discussion. I mean, I'm just joining and
> possibly there are some downsides of doing so and most probaly it has
> already been discussed, but I think it would be useful to ease the
> communication.
> On Mon, Aug 1, 2022 at 12:58 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hola Daniel,
>> None of those at time, but you could open a new discussion in github
>> (though that is in the main grass repo...)
>> Vero
>> El lun., 1 ago. 2022 19:51, Daniel Torres <nobeeakon at gmail.com> escribió:
>>> thanks Veronica, then I'll  try with the ones suggested in Hugo website
>>> (is there another communication method you guys use, like Slack, discord
>>> or something like kind of more direct or  quick questions and stuff? )
>>> On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> Hello Daniel,
>>>> IIRC, I suggested using something similar to what wowchemy (former hugo
>>>> academic) has, but the path chosen was different. Paulo, also made a
>>>> suggestion, but I didn't have the time to try, honestly. I think it's all
>>>> in the PRs and probably this issue too:
>>>> https://github.com/OSGeo/grass-website/issues/19
>>>> Vero
>>>> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
>>>> escribió:
>>>>> Thanks guys,
>>>>> I'm ok with starting on the website.
>>>>> About the search, in Hugo website they suggest a couple of methods
>>>>> https://gohugo.io/tools/search/ , have those been tried?
>>>>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <veroandreo at gmail.com>
>>>>> wrote:
>>>>>> Hi Daniel,
>>>>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>>>>> starting with something for the website, we are missing a search engine
>>>>>> there. There were a couple of attempts in the past but none of them worked
>>>>>> fully as expected. Have a look at the PRs here:
>>>>>> https://github.com/OSGeo/grass-website/pulls
>>>>>> Best,
>>>>>> Vero
>>>>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<wenzeslaus at gmail.com>)
>>>>>> escribió:
>>>>>>> Hi Daniel,
>>>>>>> Welcome. That sounds great. For Python, check this presentation I'm
>>>>>>> preparing for FOSS4G where are I describe how to do good PRs which fix
>>>>>>> coding standards and the load of tools which can be applied:
>>>>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>>>>> JavaScript at this point means starting with your own idea which may
>>>>>>> or may not be what you are looking for. Website is certainly one option.
>>>>>>> I would really like to see changes in the documentation (aka HTML
>>>>>>> manual pages):
>>>>>>> https://grass.osgeo.org/grass83/manuals/
>>>>>>> ...but that's certainly "bring your own idea." It likely involves
>>>>>>> some HTML and CSS design, but perhaps there is something more functional
>>>>>>> that can be done. An alternative to this is migrating to Sphinx first, but
>>>>>>> that's just a thought from the past.
>>>>>>> Now when I think about it, the full JavaScript checks in Super-Liner
>>>>>>> are not enabled, so that's perhaps a small JavaScript task to tackle before
>>>>>>> starting a bigger project (that's up to you!).
>>>>>>> Let me know if there is any other info which would be helpful.
>>>>>>> Best,
>>>>>>> Vaclav
>>>>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>>>>> JS and front end stuff, but also with Python.
>>>>>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>>>>>> something on the website side?)
>>>>>>>> Cheers,
>>>>>>>>   Daniel
>>>>>>>> _______________________________________________
>>>>>>>> grass-dev mailing list
>>>>>>>> grass-dev at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/eb3d5e98/attachment.htm>
