[GRASS-dev] hi
Vaclav Petras
wenzeslaus at gmail.com
Mon Aug 1 12:23:28 PDT 2022
Now, I see I misunderstood here. The Discussion is about the communication
channels, not about the website. I guess my comments are still generally
valid, but irrelevant here. Sorry for the noise.
On Mon, 1 Aug 2022 at 14:58, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> ...but I should add: Let's see what works.
> On Mon, 1 Aug 2022 at 14:56, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> There is no difference in discussing things in the PR or issue versus in
>> a Discussion in terms of notifications, no? If it is about development, it
>> should be part of this mailing list or the PRs/issues in the relevant repo.
>> I don't see what Discussion would add here. ...that's of course different
>> from considering the more "chatty" channels.
>> On Mon, 1 Aug 2022 at 14:17, Daniel Torres <nobeeakon at gmail.com> wrote:
>>> Venga, muchas gracias Veronica.
>>> Nice, thanks, I'll open a discussion. I mean, I'm just joining and
>>> possibly there are some downsides of doing so and most probaly it has
>>> already been discussed, but I think it would be useful to ease the
>>> communication.
>>> On Mon, Aug 1, 2022 at 12:58 PM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> Hola Daniel,
>>>> None of those at time, but you could open a new discussion in github
>>>> (though that is in the main grass repo...)
>>>> Vero
>>>> El lun., 1 ago. 2022 19:51, Daniel Torres <nobeeakon at gmail.com>
>>>> escribió:
>>>>> thanks Veronica, then I'll try with the ones suggested in Hugo website
>>>>> (is there another communication method you guys use, like Slack,
>>>>> discord or something like kind of more direct or quick questions and
>>>>> stuff? )
>>>>> On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
>>>>> wrote:
>>>>>> Hello Daniel,
>>>>>> IIRC, I suggested using something similar to what wowchemy (former
>>>>>> hugo academic) has, but the path chosen was different. Paulo, also made a
>>>>>> suggestion, but I didn't have the time to try, honestly. I think it's all
>>>>>> in the PRs and probably this issue too:
>>>>>> https://github.com/OSGeo/grass-website/issues/19
>>>>>> Vero
>>>>>> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
>>>>>> escribió:
>>>>>>> Thanks guys,
>>>>>>> I'm ok with starting on the website.
>>>>>>> About the search, in Hugo website they suggest a couple of methods
>>>>>>> https://gohugo.io/tools/search/ , have those been tried?
>>>>>>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <
>>>>>>> veroandreo at gmail.com> wrote:
>>>>>>>> Hi Daniel,
>>>>>>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>>>>>>> starting with something for the website, we are missing a search engine
>>>>>>>> there. There were a couple of attempts in the past but none of them worked
>>>>>>>> fully as expected. Have a look at the PRs here:
>>>>>>>> https://github.com/OSGeo/grass-website/pulls
>>>>>>>> Best,
>>>>>>>> Vero
>>>>>>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<
>>>>>>>> wenzeslaus at gmail.com>) escribió:
>>>>>>>>> Hi Daniel,
>>>>>>>>> Welcome. That sounds great. For Python, check this presentation
>>>>>>>>> I'm preparing for FOSS4G where are I describe how to do good PRs which fix
>>>>>>>>> coding standards and the load of tools which can be applied:
>>>>>>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>>>>>>> JavaScript at this point means starting with your own idea which
>>>>>>>>> may or may not be what you are looking for. Website is certainly one option.
>>>>>>>>> I would really like to see changes in the documentation (aka HTML
>>>>>>>>> manual pages):
>>>>>>>>> https://grass.osgeo.org/grass83/manuals/
>>>>>>>>> ...but that's certainly "bring your own idea." It likely involves
>>>>>>>>> some HTML and CSS design, but perhaps there is something more functional
>>>>>>>>> that can be done. An alternative to this is migrating to Sphinx first, but
>>>>>>>>> that's just a thought from the past.
>>>>>>>>> Now when I think about it, the full JavaScript checks in
>>>>>>>>> Super-Liner are not enabled, so that's perhaps a small JavaScript task to
>>>>>>>>> tackle before starting a bigger project (that's up to you!).
>>>>>>>>> Let me know if there is any other info which would be helpful.
>>>>>>>>> Best,
>>>>>>>>> Vaclav
>>>>>>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>>>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>>>>>>> JS and front end stuff, but also with Python.
>>>>>>>>>> Happy to contribute, but don't really know where to start. (Maybe
>>>>>>>>>> something on the website side?)
>>>>>>>>>> Cheers,
>>>>>>>>>> Daniel
>>>>>>>>>> _______________________________________________
>>>>>>>>>> grass-dev mailing list
>>>>>>>>>> grass-dev at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220801/88829b49/attachment.htm>
