[GRASS-dev] C code indented
Vaclav Petras
wenzeslaus at gmail.com
Sat Aug 27 11:06:11 PDT 2022
Dear all,
Most of the C and C++ code was indented using our
./utils/grass_indent_ALL.sh script at the FOSS4G 2022 sprint. This will
help to indent code for PRs and with the transition to clang-format.
Directories with files which indent reports issues for were not updated,
because more changes are needed in the code.
This may create conflicts in some existing PR which modify C code. If you
have a conflict related to this (old PR may have other conflicts too), you
can follow this procedure:
Indent your code:
./utils/grass_indent.sh db/drivers/mysql/create_table.c
Commit the change:
git commit -m "Indent PR code" db/drivers/mysql/create_table.c
Update upstream/main branch:
git fetch upstream
Merge into your branch upstream/main:
git merge --strategy=recursive --strategy-option=ours upstream/main
Let me know if you have any questions,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220827/d2e816f2/attachment.htm>
