[GRASS-dev] GRASS + WSL
Huidae Cho
grass4u at gmail.com
Wed Feb 16 07:03:35 PST 2022
Hi Brad,
I'm using GRASS under WSLackware (https://github.com/Mohsens22/WSLackware).
For me, ximgview compiles fine. Maybe, it's a distribution issue?
Best,
Huidae
On Wed, Feb 2, 2022 at 2:57 PM Brad ReDacted <brad.redacted at outlook.com>
wrote:
> Hello,
> It was suggested to me that I report to the list that GRASS almost fully
> compiles and runs under Windows Subsystem for Linux (WSL). Everything
> compiles except ximgview.
> For those who do not know what WSL is, it is sort of a hidden VM layer
> addon for Windows with a custom kernel that allows Linux to run on Windows.
> I am using the Ubuntu WSL Preview on Windows 11 with WSL2. This
> combination gives me full GUI without needing to run a separate X Server.
> Graphics are accelerated (nvidia, in my case). I have not had a chance to
> test everything, yet, but it does look promising.
> On Windows 10, you will need to run a separate middleware X Server to get
> the GUI working until the next release of WSL.
> This may eventually replace the need for MinGW for the most recent
> releases of Windows. I look forward to running performance benchmarks.
> It's linux, but it's on my Windows desktop! It's a bit surreal.
> Best Regards,
> -Brad
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Huidae Cho, Ph.D., GISP, /hidɛ <http://ipa-reader.xyz/?text=hid%C9%9B>
t͡ɕo/, 조희대, 曺喜大
GRASS GIS Developer
https://idea.isnew.info/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220216/92d18e7d/attachment.html>
