[GRASS-dev] Should we become stricter with failures in addon CI?
Vaclav Petras
wenzeslaus at gmail.com
Thu Oct 6 04:38:27 PDT 2022
Hi Stefan,
On Wed, 5 Oct 2022 at 07:18, Stefan Blumentrath <Stefan.Blumentrath at gmx.de>
wrote:
> Test success rate is at ~70 % and if I add a new failing test, that is
not considered a test failure, so I have to go in and check if the added
test actually succeeded.
The tooling improved since the rule was set up, so I would say, yes, it
should mirror the setup in the core where not-yet-fixed tests are excluded
in config.
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221006/717206d3/attachment.htm>
