[GRASS-dev] Debugging, parallelism, etc.
    Brad ReDacted
    brad.redacted at outlook.com
    Sun Oct  9 09:37:46 PDT 2022
Hello,
I'm working on adding parallelism to modules, but debugging is turning
out to be a logistical nightmare:
Why do I not get any reporting from GCC option '-fsanitize=address|thread"?
I am also having trouble getting the profiler to work properly inside
GRASS (I assume due to shell?). The gmon.out file produced has no usable
data.
OpenMP is extremely poorly supported by most tools. valgrind with
helgrind reports a lot of nonsense. I can't seem to get the Intel linux
tools to work properly, either.
BTW, we are supporting both pthreads and OpenMP. While this isn't an
issue in most cases, there can be races and deadlocks if not handled
properly. Pthreads aren't entirely portable. OpenMP is. However,
pthreads gives us a more control. May I suggest using OpenMP for most
modules and reserve Pthreads to libraries, etc? Or should we start
moving away from pthreads?
Any suggestions would be greatly appreciated!
Best Regards,
-Brad
