[GRASS-dev] PSDriver
Brad ReDacted brad.redacted at outlook.com
Wed Oct 12 23:32:54 PDT 2022
Hello,
Can someone tell me what spec the (enhanced) postscript driver
(lib/psdriver) adheres to? I am having difficulty looking up one of the
parameters (box erase, in particular - erase.c).
I found references to PostScript levels, but no mention of EPS, which is
clearly being used in this case. AFAICT, there is no such box erase in EPS.
Anyone here from way back with some info? I would like to correct some
security issues and possibly expand commands; Like adding
highresBoundingBox that will accept floats for higher precision.
Best Regards,
-Brad
