[GRASS-dev] Debugging, parallelism, etc.
Moritz Lennert
mlennert at club.worldonline.be
Fri Oct 14 02:02:59 PDT 2022
Am 09.10.2022 20:45 schrieb Brad ReDacted:
> Those variables would be...? Is this documented somewhere? If not, can
> we get it documented?
https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
> OpenMP can do far more than just loop "unrolling", these days. Tasking
> sections to run concurrent is also quite trivial. It can also offload
> to GPU, etc. Check out the v4.5+ spec. It's pretty impressive. I
> believe it can do most of what pthreads does, but you certainly lose
> control of implementation details. Some compilers have an omp library
> while others convert to pthreads.
> I do find myself rewriting algorithms so that OpenMP can handle them.
> It doesn't seem to handle nested loops with breaks very well and I'm
> not entirely sure why.
> On 10/9/2022 10:43 AM, William Hargrove wrote:
>> Can still run GRASS outside the shell by setting all of the
>> environment variables appropriately ...
>> OpenMP just works by "unrolling" all of the determinate loops, i.e.,
>> the ones that iterate a fixed number of times. No speedups to
>> anything else.
>> Speedup from OpenMP will be limited, depending on the number of
>> determinate loops present, and how much of the load they represent.
>> pthreads are totally flexible, but the programmer has to specify
>> everything, very carefully ...
>> But pthreads can speed up lots of stuff outside of determinate loops
>> HTH,
>> Bill H.
>> On 10/9/2022 12:37 PM, Brad ReDacted wrote:
>>> Hello,
>>> I'm working on adding parallelism to modules, but debugging is
>>> turning out to be a logistical nightmare:
>>> Why do I not get any reporting from GCC option
>>> '-fsanitize=address|thread"?
>>> I am also having trouble getting the profiler to work properly inside
>>> GRASS (I assume due to shell?). The gmon.out file produced has no
>>> usable data.
>>> OpenMP is extremely poorly supported by most tools. valgrind with
>>> helgrind reports a lot of nonsense. I can't seem to get the Intel
>>> linux tools to work properly, either.
>>> BTW, we are supporting both pthreads and OpenMP. While this isn't an
>>> issue in most cases, there can be races and deadlocks if not handled
>>> properly. Pthreads aren't entirely portable. OpenMP is. However,
>>> pthreads gives us a more control. May I suggest using OpenMP for most
>>> modules and reserve Pthreads to libraries, etc? Or should we start
>>> moving away from pthreads?
>>> Any suggestions would be greatly appreciated!
> Best Regards,
> -Brad
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
