[GRASS-dev] Debugging, parallelism, etc.
Brad ReDacted
brad.redacted at outlook.com
Sun Oct 16 10:47:42 PDT 2022
On 10/14/2022 3:00 AM, Even Rouault wrote:
> Hi,
> just wanted to point that if you are interested in a "framework" for
> submit jobs to a thread pool, I can point to
> https://github.com/uclouvain/openjpeg/blob/master/src/lib/openjp2/thread.h
> https://github.com/uclouvain/openjpeg/blob/master/src/lib/openjp2/thread.c
> which is a port in C I've done from the equivalent C++ code of GDAL
> (https://github.com/OSGeo/gdal/blob/master/port/cpl_worker_thread_pool.h).
> It has a pthread and Win32 implementation. It could be easily
> extracted from libopenjp2 (pending a opj_ -> grass_ renaming to avoid
> conflicts if both are combined)
> The high level API is the opj_thread_pool_* one.
> Probably not super fancy, but serves my need well. The user is
> responsible for selecting the number of threads and splitting the work
> load in jobs that are queued to the thread pool and consumed by the
> threads as soon as they are no longer busy.
Thank you for the pointers and links. I will definitely take a look at
it and see what I can incorporate. Between this and the various drivers,
I think I have more than enough to work on for awhile.
Thank you all for indulging and tolerating my questions.
Best Regards,
-Brad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221016/645261cc/attachment.htm>
