[GRASS-dev] [release planning] GRASS GIS 8.4.0
Markus Neteler
neteler at osgeo.org
Sun Jul 28 10:26:29 PDT 2024
On Sun, Jul 28, 2024 at 3:07 PM Sebastiaan Couwenberg via grass-dev
<grass-dev at lists.osgeo.org> wrote:
> On 7/28/24 2:51 PM, Nicklas Larsson via grass-dev wrote:
> >> On 28 Jul 2024, at 13:30, Sebastiaan Couwenberg via grass-dev <grass-dev at lists.osgeo.org> wrote:
> >> On 7/28/24 11:54 AM, Markus Neteler via grass-dev wrote:
> >>> I just discovered that the tarball no longer contains the version in
> >>> the tarball "grass" subdir (expected "grass-8.4.0"):
> >>> tar tvfz ~/grass-8.4.0.tar.gz | head
> >>> drwxr-xr-x runner/docker 0 2024-07-27 15:34 grass/
> >>> Why is that? Is it a feature?
> >>> It breaks e.g. the (Fedora) RPM packaging procedure...
I need to add that I had tried to use (this time) the tarball from GitHub.
> >> That tarball used for the Debian package from https://grass.osgeo.org/grass84/source/ includes the version in the toplevel directory:
> >> $ tar tavf ../grass-8.4.0.tar.gz | head -1
> >> drwxrwxr-x root/root 0 2024-07-27 13:27 grass-8.4.0/
> > The tarball from https://grass.osgeo.org/grass84/source/ is not the same as the one on Github, it also does not contain the "include/VERSION_GIT” file.
> That's obvious.
Not to me :)
> Why that breaks the RPM packaging procedure is not, as it uses the
> tarballs from grass.osgeo.org too:
> https://src.fedoraproject.org/rpms/grass/blob/rawhide/f/grass.spec#_29
Yeah, using that one all goes fine.
So, we may ignore that but may consider to fix
https://github.com/OSGeo/grass/pull/3437
Best,
Markus
