[GRASS-dev] Errors compiling main on Ubuntu 22.04
Edouard Choinière
e.chs at outlook.com
Mon Jul 29 02:41:05 PDT 2024
Could you try cleaning with « make libsclean clean distclean » beforehand? (The libsclean is the part I want you to try)
Edouard Choinière
Le 29 juill. 2024 à 05:35, Luís Moreira de Sousa via grass-dev <grass-dev at lists.osgeo.org> a écrit :
Dear all,
this morning compiling the main branch I am getting a couple errors:
GRASS GIS 8.5.0dev 4014208b4 compilation log
Started compilation: ma 29 jul 2024 10:11:18 WEST
Errors in:
/home/lads/git/grass/vector/v.profile
/home/lads/git/grass/vector/v.select
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: ma 29 jul 2024 10:15:45 WEST
make: *** [Makefile:71: default] Error 1
I proceeded as instructed:
$ cd /home/lads/git/grass/vector/v.profile
$ make
: && gcc -L/home/lads/git/grass/dist.x86_64-pc-linux-gnu/lib -L/home/lads/git/grass/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/home/lads/git/grass/dist.x86_64-pc-linux-gnu/lib -Wl,-rpath,/usr/local/grass85/lib -o /home/lads/git/grass/dist.x86_64-pc-linux-gnu/bin/v.profile OBJ.x86_64-pc-linux-gnu/main.o OBJ.x86_64-pc-linux-gnu/processors.o -lgrass_vector.8.5 -lgrass_dbmiclient.8.5 -lgrass_dbmibase.8.5 -lgrass_gis.8.5 -lm
/usr/bin/ld: OBJ.x86_64-pc-linux-gnu/main.o: undefined reference to symbol 'GEOSBufferParams_create'
/usr/bin/ld: /lib/x86_64-linux-gnu/libgeos_c.so.1: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make: *** [../../include/Make/Module.make:18: /home/lads/git/grass/dist.x86_64-pc-linux-gnu/bin/v.profile] Error 1
This discussion at StackOverflow [0] indicates arguments missing to gcc. Compiling v.select returns the same error message.
Could this be something missing from my config? Or is it a real issue that should be reported?
Thank you.
[0] https://stackoverflow.com/questions/19901934/libpthread-so-0-error-adding-symbols-dso-missing-from-command-line
Mastodon: https://mastodon.social/@luis_de_sousa
URL: https://ldesousa.codeberg.page
Sent with Proton Mail<https://proton.me/> secure email.
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240729/6c046c27/attachment.htm>
