[GRASS-dev] Errors compiling main on Ubuntu 22.04
Edouard Choinière e.chs at outlook.com
Tue Jul 30 09:11:19 PDT 2024
Yes, that would be good. It is doing the « expected » behaviour for a more extensive clean, but looses the granularity meaning of « distclean » that only cleans the dist folder, and libsclean only cleans the compiled grass libs.
Speculating here: Maybe if grass is compiled and installed, not compiling the libs from the repo results in having the system available libs instead. Is there a way to verify that hypothesis?
Something similar happened during the code sprint, when after using libsclean made the next builds work, but I wasn’t able to reproduce like expected afterwards..
Edouard Choinière
> Le 30 juill. 2024 à 09:44, Markus Neteler <neteler at osgeo.org> a écrit :
> On Mon, Jul 29, 2024 at 12:02 PM Edouard Choinière via grass-dev
> <grass-dev at lists.osgeo.org> wrote:
>> So, if libsclean was the part that made it work, we might have to look at running it on distclean (if distclean is commonly used as a « super clean »).
> Yes, "make distclean" is commonly used as a « super clean ».
> So, would this change improve the situation?
> index be8834ecf4..81390f0dec 100644
> --- a/Makefile
> +++ b/Makefile
> @@ -124,7 +124,7 @@ code-coverage-clean:
>        -find . -type f \( -name "*.gcda" -o -name "*.gcno" -o -name
> "*.gcov" \) -delete
>        -rm -f .coverage
> -distclean: clean
> +distclean: libsclean clean
>        -rm -f config.cache config.log config.status
> config.status.$(ARCH) 2>/dev/null
>        -rm -f ChangeLog ChangeLog.bak $(ERRORLOG) grass.pc
>        -rm -f include/grass/config.h include/grass/version.h
> Markus
