[GRASS-dev] Add EODAG Support | GSoC 2024 - Week 1
Hamed A. Elgizery hamedashraf2004 at gmail.com
Sun Jun 2 04:33:58 PDT 2024
Hello everyone,
Following is the week 1 report, for adding EODAG support to GRASS GIS, GSoC
2024.
*1. What did I get done this week?*
   - Built the initial version of i.eodag, found in this pull request [1].
   - Added feature for searching & downloading by product (aka. dataset)
   type.
   - Added the following parameter for searching:
      - Start time and end time. Users can specify any time that complies
      with ISO 8601, including adding the timezone.
      - AOI. As for now, it uses the current computational region, and
      supporting GeoJSON will be added next week.
      - Provider. Currently specifying a provider is required by the user,
      and search won’t be done without it. It is planned to add a way to search
      broadly without specifying a provider.
   - Added feature for downloading products by their IDs.
   - Added option for the user to specify their custom EODAG config file
   [2].
*2.*What do I plan on doing next week?
   Add cloud coverage parameter for searching.
   Add printing for relevant metadata information, in regard to the
   products found by searching, and relevant configurations set by the user.
   Add saving results as a GeoJSON, allowing users to save the search
   results locally and then load them later, to perform downloading or further
   filtering.
   Add an option to download products from a list of IDs saved in a text
   file.
   Add handling of AOI as GeoJSON.
*3. Am I blocked on anything?*
   - Currently having my final exams, but everything is going well.
My fork repository can be found here [3].
My wiki page can be found here [4].
The log of Pull Requests can be found here [5].
Any feedback is welcome!
Best regards,
Hamed A. Elgizery
[1] i.eodag: add i.eodag module by HamedElgizery · Pull Request #1090 ·
OSGeo/grass-addons · GitHub
[2] Configure EODAG
[3] GitHub - HamedElgizery/grass-addons at i.eodag
[4] GRASS GSoC 2024 EODAG Support - GRASS-Wiki
[5] GRASS GSoC 2024 EODAG Support - GRASS-Wiki
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240602/8db4d7c2/attachment.htm>
