[GRASS-dev] Fwd: [PROJ] PROJ was not updated in Zenodo
Vaclav Petras
wenzeslaus at gmail.com
Tue Jun 4 08:38:09 PDT 2024
Thanks Even. This is not clear to me. I see OSGeo/grass enabled. I can't
manage that because it says that it is managed by another user of my org.
Screenshot attached.
Vaclav
On Tue, 4 Jun 2024 at 10:29, Even Rouault via grass-dev <
grass-dev at lists.osgeo.org> wrote:
> Hi,
> see below. I also see in https://zenodo.org/account/settings/github/ that
> the OSGeo/GRASS repository is disabled. I suspect it needs to be turned on
> again, otherwise the next GRASS release will probably lack a Zenodo record
> Even
> -------- Message transféré --------
> Sujet : Re: [PROJ] PROJ was not updated in Zenodo
> Date : Tue, 4 Jun 2024 16:25:42 +0200
> De : Even Rouault via PROJ <proj at lists.osgeo.org> <proj at lists.osgeo.org>
> Répondre à : Even Rouault <even.rouault at spatialys.com>
> Pour : Peter Löwe <peter.loewe at gmx.de> <peter.loewe at gmx.de>, Javier
> Jimenez Shaw <j1 at jimenezshaw.com> <j1 at jimenezshaw.com>
> Copie à : proj <PROJ at lists.osgeo.org> <PROJ at lists.osgeo.org>
> Hi,
> I've posted the following message through Zenodo support form at
> https://zenodo.org/support
> Hi,
> The PROJ project has released a new GitHub release at
> https://github.com/OSGeo/PROJ/releases/tag/9.4.1 a couple days ago but no
> new corresponding Zenodo record has been created at
> https://zenodo.org/records/5884394 , despite the GitHub integration
> being set up.
> I see from my account in https://zenodo.org/account/settings/github/ that
> the repository seems to have been disabled, although it was enabled last
> time. It seems something regularly disable repositories... ? I've just
> re-enabled it (as well as other repositories such as OSGeo/gdal and
> mapserver/mapserver that were disabled). Could you trigger the creation of
> a new record for the 9.4.1 release ? And what's the reason for this
> apparent disabling of repositories? This isn't the first time it happens
> Best regards,
> Even Rouault
> I'm proposing to add a step in HOWTO-RELEASE so we check that before doing
> the release : https://github.com/OSGeo/PROJ/pull/4162 , pending Zenodo
> figures out why the repositories get regularly disabled...
> Even
> Le 04/06/2024 à 12:20, Peter Löwe via PROJ a écrit :
> Javier, all,
> whoever handled the latest release should contact the Zenodo helpdesk
> https://zenodo.org/support about the missing version DOI.
> BTW, the PROJ page at OSGeo (https://www.osgeo.org/projects/proj/) seems
> to be outdated (PROJ 9.0.0).
> Best,
> Peter
> *Gesendet:* Montag, 03. Juni 2024 um 21:56 Uhr
> *Von:* "Javier Jimenez Shaw" <j1 at jimenezshaw.com> <j1 at jimenezshaw.com>
> *An:* "proj" <PROJ at lists.osgeo.org> <PROJ at lists.osgeo.org>, "Peter Löwe"
> *Betreff:* PROJ was not updated in Zenodo
> Hi PROJ
> I "was" by accident in Zenodo today, and I think it was not updated with
> the last release of PROJ
> https://zenodo.org/records/10818825
> Is it still failing, Peter?
> Cheers
> Javier
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240604/99c0b119/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240604/99c0b119/attachment-0001.png>
