[GRASS-dev] Add EODAG Support | GSoC 2024 - Week 4
    Hamed A. Elgizery
    hamedashraf2004 at gmail.com
    Mon Jun 24 04:09:16 PDT 2024
Hello everyone,
Here is my weekly report for week #4, adding EODAG support to GRASS GIS,
GSoC 2024.
   1.
   What did I get done this week?
   Removed the Pandas dependency after agreeing that removing unnecessary
   dependencies would make the module lighter.
   Added sorting for the search results by “Cloud Cover” & “Ingestion Date”.
   Added filtering for the search results using EODAG crunch [1], currently
   supported methods of filtering:
      Start/End dates.
      Cloud Cover.
      Area Relation (contains - intersects - within).
      Minimum overlap (Percentage of AOI covered by the scene).
   Added Docstring for the module functions.
   All the above changes can be found here [2].
   Attended – online – and gave a brief presentation about the i.eodag
   module, for the GRASS Community Meeting Prague 2024 [3].
   The testsuite is currently drafted, as it will be edited further when
   adding more features. The draft PR can be found here [4].
   2.
   What do I plan on doing next week?
   Extend the query parameters.
   Test the module and look into the products that might need case handling.
   Add a way to get credentials on runtime (esp. Creodias [5] as it
   requires OTP for authentication).
   3.
   Am I blocked on anything?
   I am not currently blocked by anything.
Best regards,
Hamed A. Elgizery
[1] https://eodag.readthedocs.io/en/latest/plugins_reference/crunch.html
[2] https://github.com/OSGeo/grass-addons/pull/1104
[3] GRASS Community Meeting Prague 2024 - GRASS-Wiki
<https://grasswiki.osgeo.org/wiki/GRASS_Community_Meeting_Prague_2024#Monday,_June_17>
[4] https://github.com/HamedElgizery/grass-addons/pull/11
[5] https://creodias.eu/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240624/99b81151/attachment.htm>
