[GRASSGUI] grass5 - Windows HELP
Markus Neteler neteler at itc.it
Fri Feb 7 03:17:45 EST 2003
John
On Thu, Feb 06, 2003 at 04:29:52PM -0700, John Garner wrote:
> Markus-
> Didn't help.  I am unable to rename the folder ("There has been a sharing
> violation.  The source or destination file may be in use.")
it will help (hope so) - the problem is that other jobs are
accessing that directory.
Suggestion: Try to start GRASS in another directory without spaces
in it's name.
> Also noticed that there is no '.gislock5' file in the folder.  Is this a
> file created each time a new instance of GRASS is started or should there be
> a permanent file here?
It is created during the first successful run of GRASS.
Markus
> -----Original Message-----
> From: grassgui-admin at grass.itc.it [mailto:grassgui-admin at grass.itc.it]On
> Behalf Of Markus Neteler
> Sent: Thursday, February 06, 2003 3:57 PM
> To: grassgui at grass.itc.it
> Subject: Re: [GRASSGUI] grass5 - Windows HELP
> On Thu, Feb 06, 2003 at 03:42:48PM -0700, John Garner wrote:
> > Need help here.
> > Running Win2000.
> > Downloaded and installed all components successfully (I thought).  When I
> > attempt to start GRASS I get this message:
> > $ grass5 -tcltk
> > usage: /usr/local/grass5/etc/lock file pid
> > Unable to properly access /home/John Garner/.gislock5
>                                     ^^^^-- here is a space
> AFAIK winGRASS does not support spaces. Renaming the directory
> may help.
> Markus Neteler
> grassgui mailing list
> http://grass.itc.it/mailman/listinfo/grassgui
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
      Project on Predictive Models for the Environment
Via Sommarive, 18        -       38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591)           http://mpa.itc.it
More information about the grass-gui mailing list
