[GRASSGUI] Re: fix for select control?
Jachym Cepicky
jachym.cepicky at gmail.com
Tue Apr 10 04:47:32 EDT 2007
ok, thanks for it, I'll look at it
j
2007/4/10, Michael Barton <michael.barton at asu.edu>:
> Jáchym,
> I sort of understand what is happening to cause the bug you encountered
> with the select.Select control. When the mapset group item in the selection
> tree is expanded, it generates a wx.EVT_TREE_ITEM_EXPANDING event. This gets
> propagated up through the hierarchy or controls to the grandparent object,
> the GIS Manager layer tree, where it is handled by the
> wx.EVT_TREE_ITEM_EXPANDING handler method onExpandNode.
> There may be a way to limit event propagation up the hierarchy that I don't
> understand, but what I've done is added an explicit binding for this event
> (and the wx.EVT_TREE_ITEM_COLLAPSED event too) in the selection tree class.
> This calls a dummy handler in that class. Hopefully, this will keep the item
> expand event in the class where it belongs. If we can fix this, it may be
> possible to put the selection tree inside a different kind of widget if that
> is desirable. Please uncomment line #131 in select and try it out. Let me
> know what happens.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
More information about the grass-gui
