[GRASSGUI] Re: a couple of questions
William Kyngesburye woklist at kyngchaos.com
Tue Apr 24 10:01:59 EDT 2007
I think using tabs is more of a problem when tabs and spaces are
mixed.  If ONLY tabs are used, then it doesn't matter what a user's
preference is - the indents will line up correctly.
On Apr 24, 2007, at 12:13 AM, Michael Barton wrote:
> This is settable in preferences. I can also use spaces I think if
> that is
> better. Sorry if I misunderstood your earlier comment.
> Michael
>>>>>  One thing that I notice is that when we both work on a file,
>>>>> we apparently
>>>>> have different ways of indenting. This produces errors if not
>>>>> consistent
>>>>> within a method or sometimes within a class. To get in sync, I was
>>>>> wondering
>>>>> how you do indents—spaces or tabs? If spaces, how many? Glynn
>>>>> Clements
>>>>> recommended tabs and a common indent distance of 4 spaces.
>>>> yes, it must be synchronized. Hm, I am using default python-mode in
>>>> Emacs 21.3.1. On my laptop Emacs 22.x.
>>> I'm using default python-mode tabs in Eclipse. It may be a thing
>>> of using
>>> tabs or spaces. I can turn all my tabs to spaces. But a recent
>>> post from
>>> Glynn suggested that tabs were preferable (for some reason I don't
>>> remember).
>> Hmm; I don't recall that.
>> Spaces are more robust, as there's no ambiguity as to how many
>> columns
>> a space occupies. With tabs, there's always the problem of people
>> thinking that tab width is a preference, and then their code isn't
>> indented correctly (and, in Python, that means that it doesn't work).
>> If everyone always, without exception, used tabs for indentation,
>> then
>> you could change your editor's tab width with no adverse
>> consequences.
>> Unfortunately, that's a pretty big "if"; in my experience, any
>> approach which relies upon the concept of "without exception" is
>> essentially doomed.
>> Ultimately, it doesn't matter what you use so long as your editor's
>> tab width is 8 columns. If it's something else, then you *must* use
>> spaces.
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grassgui mailing list
> grassgui at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassgui
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do
if you ARE a maniacally depressed robot?  No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
More information about the grass-gui mailing list
