[GRASSGUI] Re: [GRASS-user] Some suggestions
Jarek Jasiewicz jarekj at amu.edu.pl
Tue Jun 5 14:48:50 EDT 2007
Generally If I can add one sugestion:
First it very simple: add some quick coomand for example the probably
most ofen used command is g.region res=xx
maybe small field around display manager allow to change resolution
without opening the dialog, choosing proper tab etc.. will be good idea?
Jarek
More information about the grass-gui mailing list
