[GRASSGUI] can't dock map display with AUI
Michael Barton
michael.barton at asu.edu
Fri Jun 8 12:38:27 EDT 2007
That's what I understand from the information I've received. Our problem at
the moment is that map displays are indeed children of the initial GIS
Manager/layer manager, but they are created as top-level windows (wx.Frame).
So there are a couple of questions that we will need to answer if we want to
try docking via AUI.
1) Can mapdisplay.MapFrame be changed from wx.Frame to wx.Window (or
wx.Panel or something else that works) fairly easily or will it take an
enormous amount of reprogramming?
2) If we can changed mapdisplay.MapFrame to wx.Window, for example, can we
still have dockable AUI menubars INSIDE the map display like we do now? Does
it matter if we do or don't? I can't see the digitizing toolbar to check
this out because of an apparent bug in the Mac version of AUI that makes
toolbar controls invisible. Given this, I'd argue that maybe we want to drop
the dockable toolbars, but I don't know how they function with respect to
the digitizing module in progress.
Michael
On 6/8/07 6:07 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> It looks like we can't doc the map display using AUI unless we redo the main
>> window as a wx.Window or wx.Panel. I don't know if that would be a real
>> problem to do or not.
> For a docking UI, you normally need at least one top-level window
> which cannot itself be docked. Children can either be docked into this
> window or undocked as separate top-level windows. If you undock
> everything, you end up with an empty[1] main window whose only purpose
> is to sit around in case you want to re-dock the children.
> [1] Or almost empty. There may be some components which can't be
> undocked, e.g. the menu bar.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
More information about the grass-gui
