[GRASSGUI] Re: python question - waiting for a variable to change
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Mar 19 12:20:52 EDT 2007
today, I would like introduce few changes to mapdisp.py, which will
a) make it possible to use special p.* command set (e.g. p.rast soils)
b) use exactly what you are desribing here: timer, which is regulary
checking, if something is happening..
on the other hand, I do not think, we should use this kind of code
only there, where it is really needed, because messes the code a bit.
looking at the menuform.py code, we just need to integrate it a little bit more.
I updated menuform.py, see line 342 and in gismutils.py lines 200 and 204
jachym
2007/3/19, Michael Barton <michael.barton at asu.edu>:
> I've run into a little problem that is taxing my neophyte Python
> programming abilities. However we do a popup panel for setting display layer
> options, I think it is necessary to do something along the lines of the
> following....
> 1. Start the options popup. This is currently done with a double click on
> the layer, which calls the onActivate even handler. For a raster, the event
> handler uses...
> drastcmd = menuform.GUI().parseCommand('d.rast', gmpath)
> ...to start the autogenerated GUI.
> 2. When you press the "run" button for this d.* command, the assembled
> command (d.rast + options) is simply returned.
> 3. Now drastcmd should contain a complete d.rast command string.
> So, how do I wait in onActivate until the "run" button is pressed on the
> popup and the information is returned to drastcmd (i.e., the value of
> drastcmd is changed). Or, alternatively, how can a change in the value of
> drastcmd generate an event that I can capture and process? I messed around
> with wait() (thinking about tk_wait in TclTk), but couldn't get it to do
> what I wanted.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
More information about the grass-gui
